Need some clarification…
When you press off, it should look like this.
Records to the Events Tab uploaded Video Events or records to the SD Playback?
How are you accessing the Live Audio if those buttons are disabled when it is off?
No, I do not get the power button screen. The live stream continues. The status LED is off and the cam periodically goes through its boot up sequence, flashed the LED amber then solid then off and resumes operation. It seems to not be able to complete the update internally. I do not want to reset the device for fear it will not be usable afterwards. I do not have an appropriate SD card reader/programmer set up with me to reflash the older firmware so I will leave it like this until I can do this properly.
