Cam Pan v3 won't allow me to view playback
When I click on SD Card, I see events and I see a green bar because I have it set to continuous. However, playback only jumps to the events. I can’t playback anywhere on the green bar.
I had an update that I installed earlier today, prior to that, I didn’t have the ability to even see the green continuous bar. Now I can see it but I can’t use it.
What version of the firmware and app are you using. Phone model & OS version?
Is this happening when you pull the timeline or when you use the forward and back buttons on the date picker bar?
What happens when you expand the timeline and drag it to an area where there are no event icons nearby?
What happens when you use the 30s fwd and rev buttons?
