Recently I’d bought two cam pan v3 cameras. I have configured them to save video to sd card (one 128GB, the other one 64GB). First, I tried to save video by event, but I realise that it save videos for a couple hours an the it stops, and it not save videos again until I format the sd card (usually with the wyze app). Then I changed to save video continuously, but same result: just couple hours recording and then nothing, until I format sd card.
I updated firmware to 4.50.17.25 and nothing changed.
I even bought new sd cards, (128GB, Class 10, U3, V30), Thinking the old ones are not fast enough, but I still getting the same result.
I would like to know if this issue is happening other than me, and if someone was able to fix it by configuration.
I think it’s a software issue and need to be solved in further updates, but it will not if there are no more reports of it.
The issue with SD cards has been going on for a long time with some of the Cam Pan V3 and other cams. Long Post from eaarlier this year, and there are dozens of other post on the same issue . I do not have any cams with SD issuse (yet).
Since it happens on both cameras and with brand new cards, I agree it’s not the cards. One thing worth checking next time it stops: power cycle the camera without formatting and see if recording comes back. If it does, the card and its files are fine and it’s the firmware losing track of the card, which is good detail to add in that Wyze SD card thread Antonius linked, along with an app log sent right after it stops.
Yes others are having the same issue and I agree that blaming it on the SD card is ridiculous. With that said, all you can do besides the steps outlined by wyze in the FAQ (ie factory reset the camera) is to format the card using SD Card Format Tool. If the same thing keeps happening, don’t pull your hair out, just try a different card. Buy an 8gb card from a reputable vendor and if it works without any issues, then buy one that’s larger. At least then you won’t be out $100 and still having issues. How this isn’t the number one thing to resolve with the app is beyond me.
Wyze cameras are optimized for the FAT32 file format. While cards larger than 32GB
natively use exFAT, the Pan v3 often requires specific allocation sizes to read high-capacity cards correctly. ® Wyze Forum +1
Insert your Digiera microSD card into a computer using the included SD adapter.
Download and open a trusted partition tool such as the Official SD Memory Card
Formatter or GUIFormat (for Windows).
Format the card using the following specific settings:
File System: FAT32 (Even though it is a 128GB card, forcing FAT32 resolves the Wyze format glitch).
Allocation Unit Size: 32KB (or 32768 bytes). W Wyze Forum
4. Safely eject the card from your computer.
Step 2: Clear the Camera’s Memory Cache
Before inserting the newly formatted card, clear out any bad configuration data cached by the camera:
1. Unplug your Wyze Cam Pan V3 from its power source.
WWyze
Insert the formatted 128GB Digiera card into the camera slot.
Plug the camera back into power. Listen closely-you should hear a “ding-ding” chime, indicating that the firmware has initialized and safely read the hardware structure of the card. W Wyze Forum
Open your Wyze app and verify if the card is showing storage space available. Do not attempt to format it in the app again, as this will trigger the bug cycle over.
It’s surprising that you have this issue with brand new cameras. For me this issue started with these cameras years ago and it got progressively worse over about a year or so. At first they would stop recording but a restart would get them going for a day or two. So I set up a daily automation to restart them, but then they started failing halfway through the day, end then sooner and sooner after a reboot.
I always assumed due to this gradual failure that it is a hardware issue, but since you have it with new models…maybe it is firmware.
If you reach out to Wyze they will replace them for you under warranty if they are less than a year old, BUT it would be best if you can somehow ask to send them back so they can investigate this damn problem.
I hate that people are continuing to have this problem. I love the fact that the problem has been solved. See this thread for the one and only solution to this problem.
You have to work with support to troubleshoot your issue
You have to follow all instructions that support gives you
You may have to provide support with logs
You may have to reach out to support multiple times
You will likely spend hours of your time to prove the only solution to this problem is the one mentioned above
Point support to the thread on this forum and let them know that they have replaced at least one other camera with your same issue
Your camera has to still be under warranty (more on this later)
When WYZE runs out of stock, you won’t get a replacement but a store credit instead
100% speculation and opinion:
Based on years of observation, I truly believe that WYZE is well aware of some sort of hardware issue with certain lots of cameras. I am of the opinion that WYZE is playing the odds that camera warranty’s will expire and people will not go through the above to request a replacement. After all, a new camera can be purchased for $50. How much is hours upon hours of your time and frustration worth?
You’re not speculating. You’re stating facts. The thing that bothers me is being well aware of the issue, while still allocating resources towards wasting the customers time, as if they are doing something wrong. This dog and pony show should stop at are you sure you have a class 10 card and have you formatted it using the app. If I have to go and get a card reader, find a computer, and download some tool from a different company, it’s because the camera that you sold me is unable to properly format the card for its own requirements and that’s a you problem. Maybe instead of focusing on all the BS you put behind a paywall, why don’t you make sure your device can do the formatting adequately enough on its own, so I’m not wasting my time while you pretend to be trying to solve YOUR problem, that I’m left with. What bothers me even more is making you jump through hoops that are unrelated to the issue as if they have a track record of resolving the bugged mystery glitch for most people, or for anyone at all. Why not have me blow at it while we’re at it. Maybe I’m not blowing hard enough, you know? Oh, gosh, I was blowing from the wrong side, now that i did it from the front, it verks perfect every time. Thank you so much, it was my fault all along.
My advice, if you are having this exact predicament, before you reach out, make a list of the useless steps they want you to do in your own words, and start with that. Hi, this is my issue. This is what I’ve tried and how i did it. Ive tried it multiple times and in different order on different days with different cards. The one thing I haven’t tried is to ask for a replacement. Could you please help me with that? Include your receipt and whatever info you think they might want about your purchase. If you leave something out for them to suggest, that’s on you. Be thorough, and if you have to, politely reiterate what you asked them to help you with - replacing the device, not troubleshooting. You can even mention you tried to blow at it from the front and it still didn’t work.
Have you ruled out the card? All you’ve done is post screen shots without info so your issue may or may not be related to others’. SD cards, especially non endurance ones, all have a limited lifespan.
At the very least try doing a full overwrite format of the card using the utility from sdcard.org, but if still no luck, try a different card.
