I have a wyze cam pan V3 that having trouble with the sd card not saving to the card been in there for about 6 months, Which SD card is reccomended for the camera? and whats the largest size I can use?
There are a lot of users here posting about the same issue with the Cam Pan V3 not recording to the SD so I would not spend a lot off money on SD cards until the issue is resolved. I only have V3, V3 PRO and V4 Cameras. I like Samsung cards others like SanDIsk cards.
If you want to try a new card get a smaller 64GB card because they are good quality and are not real expensive. I use 128 GB cards in some of the V3 cams and 256GB cards in the rest like the V3 Pro and the V4 cams. You can also try SanDisk cards if that is your flavor. I personally don’t think the issue is with the SD cards unless they are really cheap or fake cards.
thank you I was not aware they had a problem
If you use the search function on this forum for Cam Pan 3 or V3 Cam Pan you will see the other post. Good Luck.
Thank you I tried to put another card it worked for 2 minutes then did the same thing, what good is a camera if it wont keep the recordings
Are you accessing via the events tab? If so, don’t. Known bug with the app and Panv3s right now. What happens if you go to the cam’s live view and access the SD card there, is it recording?
