My camera refuses to continuously record to the card. It works for chunks at a time but cuts off with the message “No video at the selected time”
Are there specific settings I am missing? Thanks.
My guess is bad or counterfeit SD card. Put it in a PC and format it using SD Formatter (from the SD Association website).
You can either do a quick format and then try to fill the card with files to make sure it is actually the capacity it says it is (and doesn’t have bad blocks) or do a full overwrite format in the SD Formatter tool Either one will take a while depending on the speed and capacity of the card but will tell you if it is bad or fake.
