Why does my cam pan V3 keep switching off of color night vision to black and white
Welcome to the Forum, @prisshnoble22! ![]()
Do you have Night Vision Mode set to Auto and have the Cam placed in an area where the ambient light level is at/near the threshold where the Cam switches modes when it’s set to Auto? That’s my first thought without a more detailed description of your experience and settings. If you want the Cam to use “Color Night Vision” all the time, then you should set Settings ➜ Advanced Settings ➜ Night Vision Mode to Off[1] and make sure you’re providing enough light to the area to capture the image quality you want when it’s otherwise dark there. I’ve used Cam Pan v3s indoors in a room with a couple of standard (4 W equivalent) night lights and had good results with the video using Color Night Vision.
When Night Vision Mode is On, the Cam will provide typical greyscale night vision. ↩︎
Because you have it set to “auto” and it will use a threshold of ambient light to make that decision. One of my Panv3s is in an area that is “borderline” and I just changed it to manual so it always stays in color.
My other one it does get pretty dark in my driveway so I leave that one on auto and it switches when it is supposed to.
