Cam Pan v3: How to limit panning
I have mounted my cam pan v3 on a tree outdoor. But I find the. Camera constantly panning due to small bugs flying around. I can change the detection sensitivity. It’s already at 45. Going too low may not detect people moving around. Is there a way to limit panning only to people, per or vehucle movement?
Unfortunately there is no way. The detection zone, detection sensitivity, etc are only for logging events, they do not impact the panning.
Disabling the IR LEDs and using an external IR illuminator mounted away from the camera will significantly reduce the chasing bugs/raindrops/etc.
The only way to limit panning is use pan/scan with waypoints and disable track motion, but obviously that is not the same thing as motion tracking and may not fit your needs.
Applicable wishlist to support:
