I have several Cam V2’s and Cam Pan V1’s. All have been working great for years. Recently moved and was successful in reinstalling all cameras. Unfortunately when upgrading the software on one of my Cam Pan’s, there was a network fault and the install failed. Now when I attempt to power the camera back up, all I get is a solid yellow light, no movement on the camera like at normal power up, and I get a click about every 3-4 seconds. I contacted support to no avail. I’ve tried holding the reset button from anywhere between 1 to 40 seconds, and no change. Any help would be appreciated!
You’ll need to try to manually flash the firmware from and SD card:
Thanks WildBill. I’ll give that a shot.
