After last upgrade camera will give connectivity error code 50. Will record for approximately 30 minutes then have a blank in recording while camera will not connect of approximately 1 minute then back online for half hour or so. Wi Fi signal strength 100%
I have never seen error code 50, and it isn’t defined in Wyze’s table of error codes.
Here are the troubleshooting guides:
https://support.wyzecam.com/hc/en-us/categories/360000596591-Troubleshooting
If that doesn’t solve it, keep in mind that this is primarily a user-to-user forum. If you don’t get help here from the community, file a support request including log files. That will ensure that the logs are captured. You might want to submit the ticket right away because there’s somewhat of a backlog. You can always let them know it’s already resolved when they contact you.
