CALL THE FIRE DEPARTMENT...Maybe not
My Wyze Cam Pan reported the Wyze Lock “door ajar” alarm as a smoke alarm.
Sure am glad I was home when I received the notification.
I have had the same on the V2 cams indoor i knew it was fake due 2 there is no alarms at the location.
Wow how did that one escape testing.
I am curious what would have happened if you owned the WYZE home monitoring solution and this occurred. I’d be willing to bet that the fire department would have shown up at your home.
I’m not sure how false alarms work on a residential basis, but I do know if you’re a business you only get so many before they start charging you. This likely varies by location/department.
