Bulb Color V2 Rules differ from V1
Hello, I installed a v2 bulb in a fixture with a v1 bulb. I use rule triggers to remind my lights to turn on sun match. Color Bulb V2 does not have this option.
Is there something I’m missing? Now I have fixtures with potentially 2 colors.
I thought I had a workaround, but it flat out doesn’t work. If you have the V2 bulb in a group, you then can select action of turn on sun match. This in fact only turned it on for the v1 bulb and not the v2 :confused:
