Simplest Solution is Windows 11 with the Android sub-system enabled and the Wyze App installed.
I understand, really. And I keep trying. But all 3 of our laptops are DELL E6520, and cannot be upgraded (because of the CPU). Thanks for caring, though! All my life I was the first to upgrade to newest OS, and not to stick with old versions just because of fearing the new oneā¦
These days a Windows 11 computer is not that expensive, $200-300 will get you a decent machine.
I still run a Windows 7 machine for some legacy software and still like Windows 7 even if itās outdatedā¦
LOL, not really the simplest solutionā¦
Sure I sent you a private message here.
Seemed easy enough, took less than 10 minutes to turn on Android sub-system, install Google Play store and then install the Wyze App.
