Bought a WYZE Cam Pan, but Motion Detection not Working
Hi,
I just bought a Wyze Cam Pan from Amazon and also upgraded the firmware system to 4.10.3.50. Though I turned on motion detection and motion tracking, it is not working at all. I assume that the rolling 14-days cloud storage is the default and did not insert a local SD card. Please help me.
Thanks,
Han
Common problem with the new batch of cams.
You’ll need to revert to the previous version, then upgrade again.
I’ll try to find the link.
/edit -
Hi Gemniii,
Thanks! How do you revert firmware to 4.10.3.40?
Flash:
