Currently the first Wyze V2 connected, Works without issue. Trying to connect additional cameras. Blue Light Blinking. It will at times say WIFI connected. The APP times out every time. I have reset the router, unplugged the camera, cleared the APP cache, ensured I was on the 2.4G and emailed tech support with the Route This codes with no reply yet. Any suggestions? I really want this off my to do list and would love for these to work as I am pleased with the first camera that does work.
Whooh.
Well I have fixed the issue. I connected to my Guest network which is a 2.4 by design and simply had to reset the first camera which was connected to an extender. Took only minutes to complete. Phew. I knew there had to be an easy answer and I couldn’t be happier. Checked off my list and if I helped anyone else I am very happy.
