Josina Philomena said she will send you this
when she is done with it if the new Black V4 gets shipped this week.
You guy look all alike with the same avatar. Triplets.
AI=
Not yet. Maybe in 2096.
For some reason, the caption ‘Bone’ made me .
Here’s a for you gloating
My newest V4 Finally arrived. I need to find a place to use it but for now it is inside looking out. Josina Will send you the bone now.
Thanks, Josina P.
Mount it in the gutter clubhouse (along with your marine battery rig) and get some ‘underground’ footage of the crew?
I was a poor Navy Man when I purchased my house in 1986. It’s only 2,000 square feet, single story and the lot is only 10,000 square feet. I have managed to cover all areas even with my house having only one outdoor outlet.
The
fort across the street may not support my WIFI and they won’t give me their password.
Out , damned spot ; out, I say.
I forgot one setting on my new V4. My first time using a V4 looking out a window.
Wow. Was that a nuclear explosion?
Hope you’re okay.
Thanks, You2
Looks like you might have two settings to address:
- Spotlight
- LED Status Light
Looks like a red glow is reflecting back at you, and that’s something else I always turn off, even for cameras that aren’t behind windows, but especially for cameras behind windows. (If you’re allowing your window-facing Cam v4 to go into Night Vision Mode at all, then the Night Vision IR Lights setting may also be problematic.)
Cam status light was off and the IR lights were off. The red looking spot is just the light reflecting off the window to the lens I think but I will double check all the setting before the sun takes a nap. This is our Delta/Valley Foggy weather season, Foggy at at night until about 10-11 AM the next morning. I had to turn the IR lights off on all off my V3 cams because they kept recording 5 Min. + videos off the fog all night. I also had to turn off all the WCO because all the lenses are fogged over after about 10PM.
No retinal scarring.
ONLY!?ONLY?!
I wanted to buy the empty .38 acre (16,552 square feet) lot behind my house but they want $400,000.00 for it, so that was a big NO.
It is difficult to measure only.
