Beta v3 connection to Google nest & Google home
Continuing the discussion from Alexa won’t show live feeds:
Updated all v3. They continue to only show on Google nest for less than two minutes. Then it gets “ Camera feed not available.
v3 does not work on Google Home. Connecting>Camera unavailable (can’t reach camera)
I have unplugged both v3 and google nest for over 1 minute. Had Google nest and assistant look for devices, said devices linked.
Still no luck.
Pan cam works fine in google nest.
Sent log via Wyze app.
Don’t know how to submit log here
If you are testing the new firmware (4.36.11.4293) for the Wyze Cam V3. I would suggest posting your findings in the Beta thread for the PMs to see.
You can simply provide the LOG ID Number given to you in the App or Email. The PMs can look the logs up.
Log # 1005025
