best bang for the buck but...
have 2 wyze2 and going to get a pan. but these need to have a IP address, so we can use with our surveillance software. really a good deal, and the quality is as good as the higher priced cams of this type… IP!!!
I think they do. They show up in my network as “unnamed device”, but they have IP addresses.
If you open the Wyze app and go to Device Info, the camera’s IP address is shown.
Alternatively, if you login to your router, you should be able to see the IP addresses of all the connected devices. On some routers, you can even reserve a particular IP address to a device so it always gets the same IP.
