Battery Pro Cam constantly disconnecting on my iPhone Wyze app
In the last month or so my 2 battery pro cams constantly disconnect from the Wyze app on my iPhone running the latest iOS running Wyze app version 3.1.6 (1). It was happening on my iPhone 14 Pro Max and now my iPhone 16 Pro Max running iOS 18.0. When I connect via my MAC from the Wyze Web Live url the connection is better but still disconnects. I have a Orbi Mesh network running 2.4ghz and 5.0. From what I see on the Orbi app the connection on both battery cam pro cameras I have are using 2.4ghz. I have logged out and into my Wyze account on the iPhone app as well as deleting the app and reinstalling it. On the phone sometime I getting error code -15 or -16.
Any one seen this issue or know how I can fix it?
Similar issue here. Worked fine for a while but suddenly my two BCPs no longer connect and I get the -15 error. What is odd is that they’ll connect if my phone or computer is near the cams but that shouldn’t matter if they’re on the WiFi signal… right? Restarted router, cams, etc…
