Can anyone recommend a battery pack that will let me run either the regular Wyze Cam or Pan Cam inside my coop for at least a few days in between charges? I’m more interested in night-time checking on my chicks.
We’re hoping to install an electrical outlet at some point, but until we get it done, I’d like to be able to check in on our chicks.
I don’t think you’ll get enough power from a battery to run a camera for days, maybe a deep cycle RV or golf cart battery but you’ll need to get it down to 5V.
Solar charging a battery is probably your best bet. Read this thread.
An extension cord may be an easier and cheaper solution if you’re within 100’.
This will last at least a couple days. The bigger the mAh, the longer it will last. They have slighter bigger one for 10 bucks more. When you don’t need it anymore it works as a jump starter. The pan will likely use more battery so I’d stick to the V2. Also keep the infrared lights on only while you check on them, then turn them off. There might be some longer lasting ones that you can attach a solar panel to.
This - new battery version is coming. Meanwhile I saw (and posted) a video of someone getting over 30 hours out of a small 6000 MaH battery. I believe he was just taking intermittent stills and not streaming the whole time.
i just did the wire to my chicken coop yesterday.
i use half inch pvc pipe to carry the cable.
after it was done i found the wifi signal not enough, speedtest shows 7.6/2.4 MB down/up spped, but not enough to hv wyze plug/bulb work consistently,
most of time offline, i’ll need wifi extender
I use a 10,000 m battery pack from Anker. I get 48 hours of operation. A 20,000 pack would offer much more operation time. I also use it on a Google mini and get 2 days of constant play out of it.
I read something about wifi extenders causing problems with wifi inside the house. I was planning to look into this as well, we get decent enough wifi out where the coop is but I could see it dropping frequently.
