Sensor dropped off line… replaced battery, restarted camera with bridge and it worked for one day while showing “low”. Obtained other batteries, replaced again, same result. Batteries at 3.2+ volts. Bad sensor or is there some reset process I’m missing?
I don’t think your missing anything. Every time I have replaced a sensor battery it’s taken a long time, days sometimes, before the new battery is recognized by the app. Why? I don’t know. But it does.
You could try and clean the contact points with a pencil eraser.
Had one recently that had loose (+)positive contacts that read (low battery)…needed to be pinched closer.
Careful on the (-)negative contact if it needs a lift …hold down the solder point when lifting to bend upwards or it maybe at risk from it snapping off at the solder joint …
