Can’t find anyone else here with this problem right now. In the last three or four days, all of my contact sensors stopped working. They are showing connected in the app, but the state doesn’t change when they are opened. Can they be reset? I have had problems with them going offline, but restarting the camera always solved that. Additionally, my motion sensors are all working normally.
@kevinjdoherty1 Have you tried this? Take a look here:
Thanks. Got one of them back. The other two are showing a low battery. I have been using them for quite a while, since I bought them in early access. Thinking I should just buy some new batteries and try that out. I still have three new in the box to trade them out if I need to
You’re welcome! A set of fresh batteries should help.
