To help with root cause analysis and planning to prevent future issues:
Almost everything came back online overnight. That included lights, cam v2, switches, and a motion sensor. Plus the connection with Alexa was working again. Scale was also working this morning - but not sure if it was ever affected. The only thing that did not come back online was my Sprinkler Controller. However, after power off (unplug), wait 20 seconds, and power on (plug in) it recovered too.
The email was brought up last nite due to the issue they pushed out thousands of emails to there customers it takes a very long time to push them out
Donât give Amazon any ideas.
Yep. Also deleted and redownloaded the app. Still no dice.
They could host their email with AWS which scales well and is super reliable andâŚohâŚnever mind.
You can blame AWS as much as you want, but failure of Wyze to expect outages like this in their hardware is disappointing at least. I donât need to power cycle doorbell in order for it to reconnect. Software should be ready to reconnect when services comes online. Period. Doorbell should be functioning without internet connection. Without power cycle.
I already getting rid of my wyzecams, as I donât get promised 1080p video quality (only 360p at maximum), Perhaps, doorbell is out too next.
All of our cams are at 1080,itâs on your endâŚit was so simple to flip the breaker off/onâŚ
and itâll likely be sold as an add on with a monthly subscriptionâŚ
I never got an email. If they canât send emailsâŚI mean wow. How does it take hours to push emails out?
Itâs Friday evening (6:36 EST) and I am still unable to connect. Iâve followed every instruction and rebooted every device (and ISP router). Still no connection. Is there still a problem with AWS, or should I be contacting support? I use a number of AWS services and they are all back online. Advice?
(btwâI know that trying to answer these threads is a tough job soâthanks)
zigbee products on order⌠bye bye Wyze
See ya
I use smart life plugs GOSUND PLUGS
Same boat here. I have most with no connection still. Resetting doesnât work as it doesnât even connect to my bulb on the bulbâs WiFi. Cameras all say disconnected unless I tap on them I can view them.
Very frustrated here
Itâs not a big ask.
To get all posts (in time sequence) of any individual participating in a Topic (eg, a Gwenâs eye view) click their name then XX Posts in Topic:
Iâm sure theyâre not 100% up and running. I done ALL troubleshooting stated on this thread, clear cache, sign off/sign on, remove problem cam, power cycled, re-added in my app, uninstall/reinstall app and nada. I tried my wifes Ipad Air 2 by installing wyze on it and the one problem cam shows on it. The entire troubleshooting I done was on my android phone running android 11, wifes anroid 11 phone is on the same boat as mine. Wondering now if it just an issue for android users.
@UserCustomerGwen not sure of the status on the robot vacuum showing offline in the app. Iâm sorry if I missed in the 784 entriesâŚ
My cams are working, but 2 APPEAR offline, but are able to be accessed and live watched.
I have cleared the cache and logged out of the app but thye are still appearing that way.
I wonder what I cna do to fix that.
Hey @johnnymets
You can use Search within a Topic to narrow it down (via magnifying glass icon, upper right usually). Here are the results for âvacuumâ in this Topic.
https://forums.wyze.com/search?expanded=true&q=vacuum%20topic%3A206628%20order%3Alatest
