Auto Updates
Is there an “Auto update” feature for the cameras? I have 13 Cams and it takes a long time to update them when needed.
Yes there is but I can’t find it …
At this time, auto update is not available for Cam OG and OG-T.
For some other cam models (e.g., Cam v3, Cam v3 Pro), you can find the auto update setting at:
  • Wyze app Home > your cam > Settings (gear icon upper right) > Device Info > Firmware Version > Automatic Update
I actually have Auto Update off on all of my v3 cameras. New firmware sometimes causes problems. I will manually update the v3 that looks down on my backyard. Not an important camera as it only captures rabbits in my yard. If the update goes well, then I manually update the rest of my v3 cameras.
So, does this mean there is an auto update setting?
[Mod Edit]: Signature block has been manually removed from this post. Such information often gets included inadvertently when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
For my regular v3 cameras, from the Home Screen I click on the Gear Icon - Device Info - Firmware Version. From there I can toggle Automatic Update Off on each camera.
This link will show you the latest firmware and App versions available.
Thanks for the info.
I have a variety of cameras (Outdoor, V2, V3, OG). 17 in all. I do not see that option for all of them.
Any help is appreciated.
Don
Hey Don, more on this from a few months ago:
Click through to see the full thread. :slight_smile:
