App File download location changed form DCIM/Wyze to Movies
Downloaded Events were saving to DCIM/Wyze/Events folder on my Tablet. Now saving to Movies folder. DCIM/Wyze folder is not being updated with camera information, saved photos, or time lapse, Can the Wyze folder location be set manually ?
A tip for people with Samsung phones. Its “My Files” app lists recent files. When the Wyze app creates files, I don’t have to remember where Wyze saves its files. I turn to the “My Files” app and it’s there. I immediately move it somewhere else more convenient. Other phones might have a similar utility.
That doesn’t appear to be possible with the Wyze app itself, but apparently it’s been on the Wishlist for a while:
Yeah, this is unacceptable. Arbitrarily dumping these into a ‘Movies’ folder without notice is bad behavior. This needs to change ASAP. The default location should be user selectable in the app.
To make matters worse, If you rename or delete the ‘Movies’ folder, the app recreates it WITHOUT ASKING the user. Not cool. I am removing the files permissions from the app until this rogue behavior is corrected.
