Yeah, I have not seen a perceptible difference with the new run-in-background option on Android. I still sometimes get notifications 10-15 minutes late, and I even have battery optimization/Doze disabled for the Wyze app. My wife’s iPhone seems to receive them nearly immediately.
Often I will get a bunch of Wyze notifications all at once 10 minutes after the fact.
In addition to the continued delayed notification issue, I’m finding this version of the Android app to be less reliable than previous versions. Frequently when I open the app now I get a blank screen which either results in me having to force close the app or an unresponsive error (see screenshots below).
Same here. Woke to the new version this morning and consistently hanging, crashing and won’t display the cameras. Close app, reopen app, same thing. Close app, reopen app, then the cameras won’t display. Press the refresh the camera button and then sometimes it works. Android 11 on a Google Plxel 4 XL.
Getting Connection failed (error code:-27) on the cameras consistently while this is occurring.
For some reason I cannot update to version 2.14.33 on Android. My Wyze app version is “stuck” on 2.13.119. In my Play Store app if I go to the Wyze app page, there is no option to update - just open or uninstall. I’ve cleared the cache and data for both the Wyze app and the Play Store app to no avail.
In a desktop browser window (private, not logged into Google) the Wyze app Play Store page says the latest update was on October 13 but the latest version is 2.13.119 - that must be a mistake. Is that somehow preventing my Google/Play account from recognizing there is a newer version of the Wyze app?
Is this an older device or a tablet or something you were trying to update the app on?
I’ve had this problem in the past with wyze and recently another brand camera system.
I’m also having the issue of cameras taking up to 1 minute to connect when it used to be 2-3 seconds. It’s basically unusable. This is new behavior with 2.14.33.
I wish I had an answer for ya how to fix it.
Try restarting your phone, Make sure all of your other apps are up to date.
You could also try uninstalling the wyze app, if none of that works I suggest you contact support
And this is what the page says in a desktop browser (private mode, I am not logged into my Google account). Note how the listed app version is actually the older one from Sept 14. https://i.imgur.com/JgkUcXl.png
Whenever I have had that problem the company had to push out a new app version to fix it, but ya never know .
I’ve seen people having all kinds of strange things like that in the play store
Sadly uninstall/reinstall didn’t work. Play Store only installs version 2.13.119.
I’m not sure if it’s some kind of bug with the Play Store and my Google account, or some kind of issue with how my Wyze app install is communicating with the Play Store. As mentioned above I’ve tried clearing the Play Store cache/data multiple times. This is such a bizarre problem. I’ve never had any issue updating any apps.
The sad thing is I’ve been waiting for the new app update to see if it would fix issues that arose since the last update on September 14. Now I can’t even check that.
