It can go over it by itself…most of the time. But it looks rough doing it, and occasionally it will get stuck.
I really want it to go over that area because when I make it out of bounds, the vacuum won’t go in between or behind the chair (see the second picture).
I think you would be better off keeping it from going over that so it has to enter from the sides.
A string from one leg to the other 1 or 2 inches up would engage the bump sensor and keep it from going across. Since the no-go zone isn’t used, it will keep trying until it finds a way around one end or the other.
Is it a chair? if so, can you move it when you start your vacuuming?
If not, @SlabSlayer suggestion about putting a barrier between the leg would work well.
That’s really clever! I’ll give it a shot, thanks.
