Hello! I have yet to figure out why my 47c tells me there is an update and then tells me it is up to date. What is the latest firmware for the 47c? Has anyone found a fix for this? I have tired the basic: turn off, update app and remove re-add. The watch seems to be working fine, just don’t want to run in to issues down the road.
Thank you!
CoryC
I sent mine back and stayed with the 47
Send back for refund while you can, switch to xaiomi Mi band 6. Won’t regret it.
I also had… The same issue as you describe. When I updated the WYZE Android App to v2.27.33 the update now behaves, and the watch sync and notifications are working.
