Android app version 2.9.30 is releasing today along with firmware versions 4.9.5.111 for Wyze Cam v2 and 4.10.5.111 for Wyze Cam Pan.
These have improvements such as fixing some bugs, improving streaming with Google Nest Hubs, and optimizing the logic for the SD card eject feature.
Please note that Google has cautioned us to expect app reviews to take 7 days or longer during this time. If you do not see the update now, you should receive it in the next week or so.
Thank you for the heads-up… working well for the past few hours…
App v2.9.30 under Android 9 and 10 viewing a mix of v2 cams firmware v4.9.5.98 and v4.10.5.111
and the other way around…
App v2.8.24 under Android 6, 9 and 10 viewing the same mix of cam firmware versions. A v2 cam stream running the new firmware froze once using this older app version, but was still chugging along on the phone running the latest app version. I think I’ll update all later tonight if things remain stable.
So far so good, with regard to streaming via Google Assistant from my V2 cams (f/w 4.9.5.111) to the Chromecast dongle plugged in to my Sony TV. Initial connection took about 15-20 seconds, then a solid stream for about 25 minutes now. Is there still a time limit on the stream before it times out? Doesn’t appear to be. Anyway, good work Wyze!
To post one in the forums you needs to have a new user level that you get after making a few posts and reading threads. Maybe a Mod can up you now so you can post it. @Loki@DreadPirateRush? Thanks!
Welcome to the forums! @Loki or @DreadPirateRush will have to up your trust level since your a new user, but can you post image examples of this “sawdust” like @UserCustomerGwen asked? Lost of thanks!
