Android v2.10.3 beta crashes constantly when trying to save a new Rule
Hi, @fred2028. Wyze support and the devs do not monitor this forum. I would recommend submitting logs through the app if at all possible. :slight_smile:
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, please file a Support Request. You can also submit a request from within the Wyze app by going to Account > Help & Feedback > Submit a Log. This method will allow you to send an app log for diagnosis as well as report your issue. (Note that if you are using a beta version of the app, the log will be sent to the dev team rather than Wyze Support and will not generate a support request.)
