Android Health Connect Connection
I would love for Wyze to add the ability for the app to output data to Health Connect which is built into Android now. I have the Wyze Scale and outputting the data from that is a task to get it anywhere useful since the only options are really Google Fit and Fitbit which limits the use of the scale. Adding the ability to use Health Connect would make it so it can be outputted to whatever people want.
Firstly, I voted for this. I think it would be great.
One point, though, since we can auto-export our weight to Google fit, I’m pretty sure that Google fit then sends it to health connect, so it does automatically go from the scale to health connect at least for the weight. But it would be really cool if Wyze allowed us to also send the body fat measurement and BMR measurement now too! I can’t track those in Google fit but healthconnect does support tracking those. So it would be nice if Wyze allowed us to send those 2 other measurements to health connect now that it is supported.
I just ordered a Wyze Scale Ultra and just discovered that Google Fit API is being shutdown as of June 30, 2025 - in favor of Health Connect as the “official” replacement. May need to just ship the Ultra scale back in lieu of another choice if Wyze is silent on Health Connect interoperability.
Thanks for mentioning this! I didn’t realize Google Fit was being shutdown. I verified all that and now I am concerned too. I think this is important and Wyze should make Health Connect a priority now. I’m going to alert some Wyze employees about this.
#AMA2ASK
There appears that quite a number of us that would like to see the wyze scale connect with our android devices using Health Connect or Samsung Health. I personally am in favor of Health Connect as it integrates and tracks with a lot of devices. Does anyone know if this is going to be added? Keeping track of my progress is why I got this particular scale.
If I can’t connect my scale to what is taking over google fit, I’m just going to get one that does. It won’t be the first time I’ve lost all my data from my wyze scale. I’d rather not.
I’m not a regular reader of these forums… anyone hear whether Wyze will step up to Google Health Connect before the sunset date for Google Fit API in June (unless date has changed).
I’m keeping up on this. There has been no public word from Wyze on it yet.
Thx. The original dates I was seeing was June 2025 but I also see some other locations in the Google sphere that say early 2026… so perhaps there is a small amount of breathing room.
Wyze!, Just tell us what the hooks are and open source this feature/project… we’ll build the health connect feature for you! You have lots of users who are developers, and we can build it!
I am not seeing Google Fit as an option in the ‘authorize third-party apps’ anymore. Is anyone else having this issue?
Google Fit’s developer services and APIs were officially deprecated on May 1, 2024, and are scheduled to be shut down entirely in 2026. While the Google Fit app itself still currently works for tracking activity, Google is transitioning its health services to the Health Connect platform and the Fitbit ecosystem. Google fit isn’t going to exist anymore.
Key Shutdown Timeline
  • May 1, 2024: Google stopped accepting new sign-ups for the Google Fit APIs.
  • June 30, 2025: An initial deadline was set for developers to migrate their apps to Health Connect, marking the end of support for many direct app connections.
  • 2026 sometime: All remaining Google Fit API services, including the popular REST API, will be discontinued.
So it’s definitely not coming back. They are forcing everyone to switch to Health connect now. Since Google is removing Google fit, Wyze needs to add Health connect support for all the products that don’t already have it.
@carverofchoice thank you very much for the quick and detailed response. I hope Wyze will catch up quickly and get the Google Health integration added as an option.
Yeah, I hope so too. They did add support for it in some of the newer health products like their most recent scale, but since Google fit is officially deprecated, they need to also add it to lots of the older stuff because a lot of us rely on being able to use our health data cross-platform.
I will certainly continue to nag them about this when I have opportunities to do so. :+1:
Sadly this is still has not happened. I have the original Wyze scale which works perfectly fine. It gives me 8 metrics and I’d like to keep using it. However on my Android phone under 3rd party sync data my only choices are Google Fit and Fitbit. Both of those are basically gone. Fitbit is now Google health which works through Health Connect and the other choice is Google Fit which is no longer used.
I get not wanting to update old tech but I bet if they did it with their new scales its probably not a lot of work to make it compatible with their old scales.
I am heading towards a Google Health focused system. I am playing to get the new Fitbit Air band, and a scale that will import as much data as possible to Google Health (hopefully more than just weight, body fat, and BMI)
Also getting rid of my remaining Wyze cams for some Tapo’s next Prime Day.
