Well don’t worry, hubs are typically no harder than setting up a Wyze camera. So if you have been able to setup your Wyze devices, I have faith you could setup a hub.
But yes, voice your concern but what they showed back in February, it’s in beta testing so that generally means hardware is pretty set and it’s software tuning left. There will only be so much they can/will do at this point in the process.
I just want people to know that hubs are not hard to setup. So please don’t be afraid to use one if there is a product you want to purchase…Wyze or not.
I guess I’l wait until it’s released but if it is a must to connect to Google, Alexa or Siri that is one turn off. Also I have need of 24/7 live viewing. So I’ll see what the final release is before making a judgement.
Same here! I currently have 5 V2’s inside looking out. I am holding off on getting outdoor cameras until Wyze releases the outdoor camera. If it does not let you plug it in and record continuously then I will go with something else. I don’t trust PIR sensors to pick up every motion event. I was it to record 24/7.
Another advantage of the hub is that you have one device connected to your router, not several. After all, most routers are able to serve no more than 30-50 WiFi devices at a time. So count - 3 TVs, 5 phones, 3 computers, 5 smart speakers … - there are not many WiFi places left on router for smart devices …
And with the help of the hub in one WiFi place you can hide up to 30 smart devices (cameras, switches, lamps, sensors, etc…)
I agree. Hubs definitely let you hide devices. I have 60 WiFi devices and if it weren’t for hubs from other brands I’d be well over 100. But my router is handling the 60 quite well
I like the idea that the hub communicates with the cameras to turn Wi-Fi on and off. That seems valuable. And generally speaking, “hubs” connect a wide variety of devices that don’t communicate via WiFi at all, to our networks. As long as a hub that communicates over Wi-Fi doesn’t share an overlapping channel with your other Wi-Fi Access Points, then, offloading load from low-end Wi-Fi access points is a plus. But if you are in a dense neighborhood or you have several APs of your own to cover a larger home, a WiFi hub can introduce interference. I see this with my Arlo cameras. The hubs share wireless channels with my APs and those wireless packets collide with the wireless packets from other devices. No matter how many APs/hubs we have, we share the same group of wireless frequencies and wireless traffic competes for that limited bandwidth. In the case of Arlo base stations, I don’t get to control the channel they use and they seem to follow my APs when I attempt to separate them onto different channels. I connect as much as possible with wires and save the wireless bandwidth for devices that are truly mobile. And personally, I’d rather have control over which devices use the WiFi frequencies in my home and how they use them. Though I understand that most people have a single modem/router/AP device provided by their ISP, so it may not be an issue at all unless they live in a multi-unit building or a dense neighborhood.
This is one advantage of living in a sparsely populated area. Not much to worry about but your own equipment. But also have down side of not getting top end speeds of the metro.
Gave up on waiting for the Wyze Outdoor Camera and bought some Reolink cameras… they are awesome! I highly recommend them! More expensive, but they were so easy to set up and have been working flawlessly without any hiccups.
Good for you but I highly recommend waiting for the outdoor camera from Wyze . Feature and price it’s a big issue with me. I want all my cameras and door sensors and door lock to work together, if I go with another company I will have to change out everything and that just doesn’t make sense. Being impatient shouldn’t cost you more money.
I’m excited about the doorbell. The video doorbell I think will be awesome.
The thermostat really scares the crap out of me. That is something that you really can’t have problems with. You can’t have glitches you can’t have firmware issues you just can’t have them. And let’s be honest Wyze is known for having issues with products when they’re released and some of them can go on for a long time. So I would not be an early accesser for the thermostat. I would have to wait until it’s out at least a good year and see that people have worked all the kinks out before I would even think about it. That’s just me. Because it’s a thermostat goes bad and you can’t run your heat and Wyze says they’re going to replace it that’s great but they’re about going to have to overnight it to you. I mean it’s not like a camera where you can live without it for a couple days or even a week. If it goes bad you need it fixed now
I think I’ll be waiting a few months after the outdoor camera comes out.
There’s been too many issues with the band, lock and scale for the outdoor camera to come out unscathed; I don’t want to end up being a guinea pig no matter the cost of the camera!!
There’s too many things I’m worried about these cameras and the lack of any info from Wyze doesn’t help at all!
I didn’t buy the band or the scale but I did buy the lock and it’s working pretty good for me I have two of them and both unlocked with the keypad every time and my door automatically locks when I close it every time to except for when the kids forget to close the door all the way
My main worries about the outdoor camera is that it’ll have the same person detection, zone detection customization, etc as the current cameras which leaves much to be desired in my opinion.
They haven’t worked out the kinks for the current cameras and I don’t want to waste my time on a not-ready-for-prime-time outdoor camera.
I’ve been burned before and don’t want to waste any more money…
We don’t know much yet. Because it is battery powered we are assuming it will only record when tripped by the PIR but I’m hoping that if you plug it in it will then be able to record 24/7.
They have a big announcement coming up on the 23rd and or 26th of this month if they do not release the outdoor cam I will stop using all Wyze products From the announcement picture it looks like they’re releasing the doorbell is the same photo that someone else has sent me of the doorbell I know they plan on coming out with several things I mainly concerned about the outdoor cam because I cannot plug in the camera where my car is parked starting to get very frustrating to have your car get broken into and have no camera
