Allow Garage Door Controller to use Wyze Entry Sensors to determine door is open or shut
Prior to using the GDC, I used a Entry Sensor v2 to determine if my Garage was fully Closed or Open (Other than Fully Closed)
I’d like to see the GDC have access to the status of that Wyze Entry Sensor to determine if the door is fully closed, instead of relying upon the V3 Cam (that could move) or the QRCode on the door (that could be blocked)
Not everyone has Entry Sensors, so this would be an option to use instead of the camera/QRCode Method.
SJ
[Mod Edit]: Tags modified to enhance search clarity. Note that this request is fundamentally different from “Garage door controller as Home Monitoring sensor”.
There are several good reasons for this idea.
For example, instead of having mine hooked up to the Garage Door itself, I have mine plugged into a remote control which controls the door. With a remote control we could have our cameras placed anywhere in the garage, even in the far back corner or on the side facing the house entrance or whatever else. It would also allow the sensor to double as part of the HMS security at the same time.
If Wyze doesn’t do this for the current model, they should definitely consider it for a future model. :+1:
V3 cam and garage controller use separately.
Intregrat a way to use the garage controller without the camera, so you can use the v3 cam somewhere else. So in other words use the controller without the camera (If wanted)
[Mod Note]: Your request was merged to this existing wishlist topic because without a Cam v3 “looking” for the QR code, your garage door controller needs something to determine door open/closed state.
Wyze what is the status of this wishlist item? Using a wyze contact sensor to determine open closed status is a must have basic feature. The QR code while novel, is not a consistent accurate method.
I’d like to stop using my nexx garage opener but can’t due to wyze not offering this option.
This would be a great idea for using the garage door controller with a garage rolling door. I have used for a couple of years and manage to print a much smaller version of the QR code and attached to one of the partitions of the rolling door, but it works intermittently.
Wise any update on this? It’s actually crazy that you offer contact sensors that we can’t use with the garage door opener.
