So I have a v3 wyze cam and garage controller. They work perfectly fine but when I use Google assistant to open/close the door, the status of the garage door is wrong. Like it will say it’s closed when it’s open and vice versa. It goes out of sync if I open the garage any other way. For example let’s say I open the garage with the wall button. Then I get in my car and I want to close the garage but Google assistant will say that “the garage is already closed”.
If I then tell it to open the garage (that’s technically already open) it will then close it but I’d rather everything work as it should
Welcome to the user-to-user forum, @Elflamablanca!
I’ve never used the Garage Door Controller with Google Home, but just to check that the GDC is working correctly otherwise:
Is Cam settings > Accessories > Garage Door Controller > Garage Door Notifications > Garage door opened or closed turned on?
Is the garage door status correct in the Wyze app and through notifications, including when you open & close the door with the wall button? (The system will need about 10 seconds to notify you of door closed, and about 30 to notify you of door open)
- If no status changes, try recalibrating the QR Code in Cam settings > Accessories > Garage Door Controller > QR Code Detection > QR Code Calibration.
- Is the status correctly shown in Cam settings > Accessories > Garage Door Controller > Garage Door Events (including when you open & close the door with the wall button)?
- If no history log, cycle power to the camera and try again.
More info:
