All wyze v2 sensors have died
All sensors have died. Internet is strong. I’ve reset them all. Replaced batteries. Is there a bug on the wyze end that needs fixed.
I just checked mine and they are working.
Try restarting your hub: firmly hold in the reset button without letting go for around 9 or 10 seconds until you see the LED lights on the hub flash, and then immediately let go. This will force the hub to restart And try to make a new fresh connection to all the sensors.
Consider also restarting your router and your modem for your internet.
I’ll give it a try. Thanks !
It worked like a champ ! I appreciate the assist. Thank you!
