All my cameras are down. This happened a while ago and wasn’t sure back then what it was. Anyone else having this problem?
Mine seem to be fine.
Did you try rebooting your router? Or maybe you have a brief power blip and the cams need a full reboot?
All kinds of issues today. Sometimes the cams won’t load, and some times app will show no events found even through there are dozens. Force close the iOS app, open and the cams will load and events will show up. I did an update to iOS yesterday to 18.3.2 and it worked fine yesterday after the update. Just restarted my phone all is working for now. 2.4 network is showing 100 down and 40 up.
If I tap reset services it shows “Loading” for about 45 seconds to 1 min before it finishes when previously it would reset instantly.?
I had one Cloud video a couple of hours ago that would not load/play. Other than that all of my Wyze cameras are operating as they should.
Haven’t seen anything on Android. Maybe IOS app updated?
Try restarting your phone router or both
