Alexa Wyze Camera settings missing now
Cant believe this hasn’t received more attention as now (within the past 5 days or so) every echo device we have is getting “someone was detected at ___camera”, preceded by a really obnoxious ring ring, along with a video feed, on every alexa screen device- simultaneously. The settings to adjust this in alexa app are gone for all wyze cam but the v4 and cam pan duo. Either you enable or disable the camera.
We need our alerts, not on every device. We have most alexa device on do not disturb which makes them get NO notifications at all, no drop in feature, it renders them pretty much null and void.
PLEASE wyze folks, fix this tonight, like asap we cannot wait to have this fixed. If it’s amazon’s issue then work with them to get this fixed asap, like now please.
Being discussed here as well:
Not to pile on, but I’m piling on: I recently upgraded to the cam plus for ALL cams. Now not only can I NOT enable some cams, some other cams are announcing, and I cannot disable them for love or money. Disabling announcements on the cam does not stop Alexa from announcing person detection. Removing and re-adding the cam didn’t work. Unlinking and relinking the Wyze ↔ Alexa app link didn’t work. So now I cannot ENABLE or DISABLE on any of my V3 cams.
It’s very odd. Some people still get the announcements, others lost that ability.
Curious if it’s country specific (I’m in Canada).
The setting to enable/disable Person announcements is missing and has been for several months.
The one V3 camera I have, which I am paying for CamPlus specifically for the person detection and announcements, is basically useless for the purpose I bought it for.
My CamPlus subscription comes up for renewal in a couple of weeks.
If it’s not resolved by then, I’ll be cancelling CamPlus.
I’ve had to set up a Eufy camera to get person detection announcements via Alexa.
I’m in the U.S. so I’d say no.
I’m in US (Philadelphia), so doesn’t appear to be a factor
