Thanks
You’re welcome! ![]()
I just got my Wyze bulbs and have them all hooked up they are working fine in the WYZE app but Alexa says server on responding
Is there a fix?
I am the air Alexa app sees the bulbs as I add them into the Wyze app.
Go into your Alexa app and disable the wyze skill and then re enable it , that probably will fix it
If the disable and re-enable advice doesn’t work, please reach out to our customer support team.
That’s what mine does!
