Alexa can't control wyze bulb color Group
When I give Alexa a voice command to turn on a group she says, “Living Room Light doesn’t support that”
Welcome to the forum @orocasa
You are correct, Alexa does not see the group you create in the Wyze App, it only identifies the individual devices.
You will need to create a group in the Alexa app if you want to manage a group of devices with Alexa Voice commands.
Did you maybe intend to write “create a group in the Alexa app”?
I mostly use Google Home and those smart speakers with Google Assistant, but I really like the way the Alexa app allows me to create not only device groups but also nested groups (I can create a group and put that within another group). That’s handy for controlling a number of light devices and/or fixtures at once and in different ways.
Welcome to the Forum, @orocasa! :wave:
Whoops I did. What I get for working late then posting… Edited. Thanks for the call out.
You’re welcome, and thank you for being so generous about that. I just didn’t want @orocasa to be confused with the advice. :+1:
Thanks everyone. Problem solved!
