I have an Amazon Echo in one of the rooms, and a Google Home in another. I would like to get alerted if a motion is detected. Is this possible or are there any API’s that will allow me to do that?
Amazon integration is in beta testing right now. No word on Google Home integration.
Good to know RickO. Thanks for that ![]()
Are you aware of any plans to open up the API allowing users to contribute these extensions?
I am not aware and I kind of doubt that’s going to happen.
As a follow-up question, will existing models be compatible with Alexa/Google? Or are you going to release new models with Alexa/Google ready integration?
I want to know if I should just wait for this newer models or a simple firmware update will suffice.
V2 and Pan only. V1 hardware will not support it.
