Is there a way to setup a rule to start on manual turbo to run all night? We need the cleaning but also use the noise for sleep.
Welcome to the Wyze Forum @rlm729
No rules for Turbo Mode but…
If you go into the Air Purifier Main Screen and Click on Manual at the bottom you can lock the device to Turbo Mode and set it to run for 8 or a custom amount of hours.
You can also visit the Wyze Wishlist and request this capability
https://forums.wyze.com/tags/c/wishlist/12/air-purifier
Already there in the above Wishlist. ![]()
My smart home runs on Hubitat Elevation. I have a Tuya Fingerbot attached to the air purifier to change fan speeds with a rule.
These little things are amazing. I have one actuating each key fob that locks the vehicles at 9pm. Being a mechanic, cannibalizing a remote and programming it to the car was easy.
The delay is because Google has to send the command to the HE hub, then the HE hub sends a command to the Fingerbot.
Very cool! ![]()
how do you get the fingerbot finger to activate the button? do you have to add something to the finger for the purifier to sense the capacitative press?
