Custom Programming Air Purifier
Hey! Looking for a way to customize the air purifier so that it runs at max speed for 30 minutes a couple times during the day and then goes back to it’s original setting. Not sure if this is possible, but figured it was worth the ask.
Thanks
Stan
You can kind of do this with the Wyze skill on Alexa.
What I do is have it set to turbo speed, then wait 2 minutes, then set to turbo speed again and repeat for as long as I want it to go. Then I have it set itself back to auto after the amount of time elapses.
thank for the reply - i do not have an Alexa, and it looks like it does not integrate with Home Kit. Wish it could work IFTTT logic.
