After update Sd card still not recording
After the resent update, sd card still not working. It records at first. Then it stops recording & now it says SD Card not supported.
Welcome to the Forum, @stayzhigh! :wave:
What camera(s) are you using? Have you checked out this topic where Wyze is soliciting data from users having issues with microSD use?
SanDisk Micro SD card
I finally got my camera V4 pan to work with the SD card. My guess I was using a cheap brand so I purchased the SanDisk micro SD card and it’s working fine on all cameras.
[Mod Note]: New topic merged to original topic for context/continuity.
I have had good luck with SanDisk. My oldest SanDisk 32GB High Endurance Micro SD card has been Continuous Recording (in a Wyze Cam v3) for over 4 years.
If I had to rank what is currently available for cam use:
Samsung High Endurance
Sandisk Max Endurance
Sandisk High Endurance
That’s just personal opinion/observation and I’d say any of them should work perfectly fine and give years of reliability.
Unfortunately with current memory prices people are grabbing bottom bin (Team Group, Adata, etc) and expecting them to last, and they simply won’t. Even some of the cards from Samsung and Sandisk that aren’t designed for this sort of use will have a much shorter life. Or they’re buying what they think are brand name cards for low prices from Ali or ebay or even Amazon 3rd party sellers and getting scammed (often thinking it is a device problem and not the card).
