How do I add cam v3 to an installed floodlight cam ?
Do you want to add a second V3 using the USB port on the floodlight or replace the existing V3 that controls the floodlight?
I want to add a cam v3 to an already installed floodlight cam.
I’m not sure what a v3 pro is. I just have a stock cam v3 that I want to add.
I want to add a cam v3 for more coverage. Can I just plug it into the usb port or do I need to reinstall the pre-existing floodlight cam that is already installed ?
@Rulwiz is the floodlight expert and can post in with better details…
But I believe the add on V3 only uses the USB port on the floodlight for power.
So, regular install just like any V3, set it up indoors on the kitchen counter. Once set up, mount it, plug it into the floodlight USB and go. It will just be another V3 on your Device List Home Page.
Great ! Thank you all for the info. I’ll follow your instructions for the v3 add on.
