How to I mount a 2nd v3 cam on the Floodlight?
Is there a way to mount the 2nd v3 cam directly on the Floodlight? or do you just attach it directly to the house somewhere, and use a long USB wire back to the Floodlight?
I’m installing my Floodlight in an overhang mount with the included cam pointing directly down the driveway. I got this because I’d like to have a 2nd cam on the unit, but pointing 90 degrees off to the right side, looking up the front walk.
This :point_up:. And you don’t need a data cable for the 2nd camera, as it doesn’t interact with the floodlight other than to get power from it. :slight_smile:
Just came back to say thank you for that feedback.
That’s exactly what I ended up doing.
