Does Wyze provide an interface? / api? so that programmers can add IFTTT triggers and actions?
Sorry, Wyze does not provide an API at this time. I believe there is a Wish LIst items for it
Action suggestions for Wyze Color Bulbs:
- Change color to a user-set RGBA value where the alpha value is used for luminosity. Or otherwise, allow for the user to set color and luminosity.
- Have an option to select grouping made in the Wyze app.
So now that Smartthings integration is fully dead, this integration seems even more important. And if not this, the Matter integration better cover this wishlist of triggers/actions. Is that the plan?
I would like to trigger the robot vacuum to clean every time an IFTTT event comes in from my Litter Robot (a smart IFTTT connected cat litter box). So I guess the ask here is the ability to start the robot vacuum from an IFTTT command.
Any updates here or is this topic doa?
Wyze climate sensor above/below temperature a must have trigger to consider
The Wyze App allows to the following Triggers:
I realize that this is not IFTTT, but might be somethign you can work with.
Thanks but I need it on IFTTT because I am not using just plugs to control the climate. I have remote control devices and other relays.
Not a problem. I don’t use IFTTT anymore, so not sure what is available there
Did any of these get added?
I really want my Move Pan Cam to a specified waypoint feature
How about person detected event message notification. Not motion but person.
YES! I want this feature… Sooner, I hope…
73, Gary
IFTTT Event For Garage Door Open
I’m not finding that there is an event for IFTTT to consume for when the Garage Door Controller detects the door is open or has been left open. It also seems that the motion detection may be muted when the door is detected open, presumably to eliminate duplicate alerts when the door opens (one for the motion and the other for the door being open) the event muting seems to make using the motion IFTTT event less useful.
Yes, I need the ‘person detected’ trigger please!
But really, all the Cam Plus events (pet, vehicle) etc should trigger IFTTT.
Looking at all the triggers I have one that I would like to see added. Using the keypad make a trigger for disarm, home and away. By doing that we can have the keypad trigger other things instead of just the alarm system. I would like to see that trigger be added to IFTTT.
Can the Thermostat get some IFTTT love? Similar to the Sprinkler Controller, it’d be awesome if some weather detection could be done and the Thermostat adjusted accordingly. e.g. Disable, heat, a/c, humidifier, or anything given certain temperature conditions.
More specifically, adjusting the humidity level based on outdoor temperature would be priceless!
Love this wishlist and have one action I would like to request be added that I didn’t see mentioned in this thread.
Action: turn on/off the lamp/bulb (with the lamp socket accessory)
This would also provide an alternative solution for those requesting smart home voice commands (Alexa or Google Home) to trigger the light on/off using a voice command (via IFTTT). Only being able to manually turn the light on/off by opening the app and into the camera settings has been very frustrating.
The IFTTT motion trigger activates after the entire motion event has finished. I require a trigger that activates immediately after the motion event starts. Thank you!
Arm/Disarm Cam Protect through IFTTT.
