Add/edit rooms button (Robot Vacuum) missing in app
Vacuum arrived, charged, synced, and completed first vacuum of entire floor without any trouble. I was also able to add blocked areas very easily. However, I have no option in the app to add or edit rooms. Is this just a glitch in my app? I did try deleting the app and reinstalling, but no change. I did update the firmware on the vacuum before ever using.
I do not believe it is a glitch in your app specifically. I also do not have an option to “manage rooms”, and it sounds like it’s currently not an available option as it’s been brought up before by others. I read a post from earlier that had mentioned this option used to be in there, but it was removed. I assume they’re doing some troubleshooting so hopefully it will eventually be back on a future update.
