Accidentally bumped side button on Outdoor Cam Base
Changing to Cat 8 Ethernet cable, I accidentally hit the side button on the Base.
I have Misplaced the set up instructions.
Allowing the rapid blue flash to attempt to re-set up hasn’t worked. Nor has power cycling.
I have had 3 cameras connected for a few months now and would rather NOT set them all up again.
Any help is appreciated.
Well if is flashing blue it is not connected to your network. Did you try another cable?
Well, apparently it now defaults to wifi and connecting an Ethernet cable turns the wifi off… at least this is what seems to have been my problem.
Thanks
