Is there a way to use RTSP or other method to make the Wyze Cam output visible from any browser on the internet?
If you use the search bar and type in RTSP you will see that RTSP is possible some people are happy with it some people aren’t but I would start there
Here is the information for installing RTSP. I have it on one cam and it works fine on VLC so but only on local wifi.
Another option is the just released mod to change your cam to a dedicated webcam. Word of caution; unsupported modification provided by Wyze in response to the Covid crisis and the cam will not be usable under the app.
https://support.wyzecam.com/hc/en-us/sections/360008414591-Webcam-Firmware-Update
