Thus is my defective V3, where the focus is stuck on close-up. It has since lost the ability to detect the storage card. Maybe the slot is just dirty.
I don’t think he has missed to many meals.
Maybe the contact pins on your card are are dirty ? Have you tried different cards?
Yes, I put a new card in there and get the same msgs.
I keep a can of CRC Electronic cleaner for stuff like this.
Whatever you do, don’t blow into the camera.
Thanks, I put it on my wish list for later. I’m glad you said that because I was going to blow into it! 🫨
Forgot to ask you use it. The description doesn’t say.
Spray right into the SD card slot, with the slot facing down. Just a spritz.
If you blow into it, your breath contains moisture which will cause corrosion.
Thanks. Will get it next week. Could I stick something soft in there to try and clean it?
I wouldn’t stick anything in there. Might damage the connector. The electrical part is too far inside to reach anyway.
Could be a bad camera but cleaning is easy.
Ok thanks. I may eventually replace it with a V3pro. But I’ll use it until it dies.
Thanks to whomever for removing the Vietnamese spammer.
Better get them back
Get them back?
The person who deleted the first spammer
I’ll just flag it and see what happens.
Ohh ok. Haha, I wasn’t sure what you meant. Yeah, I did flag the last one.
Please do not spam.
I saw your friend was back with a new name and got erased again.
Oh good.
