90 degree angle on outdoor plug
Most outdoor outlets are mounted outlet facing directly out from a house or whatever surface they are mounted on. When you plug an outdoor smart outlet into that which is a traditional plug, it tends to stick pretty far out from the wall it’s plugged into before it can hang down.
90 degree angle plugs allow the smart outlet’s main control box to lean more sleekly down with gravity and creates a better look for almost all uses.
Welcome to the Wyze community @Fortheboys!
Would any of these options that @carverofchoice listed work for you?
Wyze Outdoor plug-change plug
Make the male plug a 90° connector. The device is designed to hang down. Having a straight plug makes it harder to fit in cramped spaces and makes for a stressful bend in the supply wire. Easy manufacturing change.
[Mod Note]: Welcome to the Wyze community k-r. Your topic was merged to this #wishlist request for better visibility and consistency in grouping similar requests. Remember to scroll up to the top and click the VOTE button.
Have you thought of designing the plug on the outlet to be flush in order to accommodate outdoor electrical outlets. Currently mine remains open when in use.
